- Joined
- 7 Sep 2016
- Messages
- 3
- Reaction score
- 0
- Country
My 5 year old Biasi Riva Compact M96.32m boiler has started cutting out. A bit of fault finding with the manual pointed to the air pressure switch being an issue. I changed it and all worked for a few days but now I'm back to square one.
If I turn the hot water on the boiler starts up as normal humming away but no flame just an error light pointing out the air pressure switch. When I remove the internal cover to access the air pressure switch the boiler fires up as expected but as soon as the internal cover is replaced or very soon after being replaced cuts off again.
Any suggestions where the fault might actually be?
I've had a previous bad experience with a rip off boiler repair guy and i'd like to at least know what the fault is likely to be before I call in the the pros, or even better if its something I can fix.
Cheers
Cheers
