Hi, Newbie here...
After trawling the Internet for countless hours and not having much luck, I thought I'd post my question on here and hope someone can help
I have a Biasi Riva Compact 32HE MK 2 (I think it might be turbo charged) and have installed a Salus RT500RF Programmable Thermostat.
I have removed the internal loop between Terminals 1 and 3 within the boiler (as indicated by the manufacturers instructions).
I have wired my thermostat as follows:
L (in) COM to Terminal 1 on boiler
SL (on) NO to Terminal 3 on boiler
I have wired the reciever unit as per the munufacturers instructions and have tested the connection between the transmitter and the reciever and they are paired up.
However the boiler does not fire up when the thermostat is calling for heat. I have disconnected the internal clock and re-connected it to see if might make a difference, but nothing.
Any suggetsions would be a great help. Also would anyone know if this is a 230v or 24v switching boiler as maybe I might have messed up the wiring pattern. Also, is the black wire in the middle of the terminal block in the boiler redundant or do I need to loop to it from Terminal 3 or 1.
Yas
Yas
