Hi i have a problem with my boiler, if you turn hot tap or put heating "on", will only work for a short time, then goes into lock out mode, then have to reset, can anyone help?
Hi, the centre light goes red not flashing, the other two are greenThere is a fault finding set of neon lights on this model , depending on what is flashing or how they are on should or might give you an indication as to what the fault is ??
Hi KarenKaren, at this time of year its usually a frozen or blocked condensate outlet pipe.
If its outside then pouring hot water over the pipe may help. A hairdryer is a waste of time.
Tony
