Hi everyone. I've got a Biasi S24 combi boiler which is playing up.
When I put the central heating on, the boiler fires up and starts heating up the water. Then, after a minute or so, the gas seems to switch off.
I can see the spark trying to relight it, but after a short time, it stops and turns on the lock-out signal lamp.
If I reset it, it happens again, but the heater stops after 30 secs or so.
If I reset it again, it happens again, but again, only works for a shorter time, until it stops lighting completely. I leave it a few minutes, and then I can start it up again for a minute or so, and then the same problem comes back.
The same happens when a hot water tap is switched on.
Nothing has been done recently to the boiler or system.
It looks like the gas supply just fades out - something is switching it off and keeping it switched off for a few minutes.
Any ideas? Many thanks in advance....
