The OH has asked if we can fit a bidet sprayer in our standalone WC that we're currently renovating. Trying to do this within regs, (without spending a fortune), it seems, is virtually impossible. WRAS seem to suggest a DC pipe interrupter could be used, however as the sprayer would be isolated once it's turned off, this would likely cause the valve to leak... so that's no good and there goes my 'cheap' option.
My second option is to provide an AA air gap. My question is: as I am fitting a new (plastic) cistern and concealing this above the room for reasons I won't go into, would it be a terrible idea to take a separate feed out of the cistern to then provide flow for the bidet spray? This would effectively save me from fitting a second cistern... unless anyone can recommend anything different!
I could then feed this via a small water heater. I anticipate that the pressure should be enough from a gravity-fed supply to not require a pump as well.
Anyone got any experience with these?
NB: I'm also aware that this is notifiable work but unless I can find a reasonably inexpensive way of making it work then it won't be happening anyway!
