- Joined
- 5 Aug 2009
- Messages
- 28
- Reaction score
- 0
- Country
Hi guys, after some advice, ideally before lunchtime today when I meet up witha builder to discuss his quote.
I've just had planning permission passed on a single storey kitchen/diner extension measuring 6x5m and my worry is the big difference between the two quotes Ive had in.
The extension is to consist of a large (1.5mx3m) skylight, flat roof, upvc double glazed french doors with 'matching' full height glass panels either side, an above average number of electrics work (20 double sockets, 20 downlighters/light fittings in addition to LED plinth lighting and under unit lighting), moving an existing or installing a new boiler etc and fitting a new kitchen.
The priced job should be consisting of everything from 1m deep footings dug to floors and walls tiled!
All Ive agreed to supply is sockets, light fittings, the actual kitchen units and appliances and a new boiler is required.
Now, here is my problem, one which has actually kept me up most of the night worrying!
The first quote I had at the beginning of last week came in at 34k. This is for a guy that was recommended and from all that I've since heard, his work is exceptional BUT he stated he had been as aggressive as possible on the pricing front for me.
I received a second quote yesterday for £25,500 "for the identical spec" - both builders had copies of the architects plans to take take a way before quoting and I had the same conversation with each regarding my expectations.
So, not being an expert or even very knowlegeable at all on electrics, building techniques etc etc should I be worried by the difference.
Financially it would make a big difference to mine and my families life if we could go with the cheaper quote but Ive always believed that you get what you pay for! Is it as straight forward as; if the job is much cheaper then corners will be cut?!
Just how can there be such a difference in the quotes; £8,500 difference on a relatively small job doesnt add up to me?!
Any advice on any specifics I should be asking the builder about how he is achieving this cheaper price would be VERY greatfully received. As I say, the cheaper quote seems very good indeed but I have this large nagging doubt in my head. The guy is keen to start Monday and the only reason mentioned by him for being cheaper is that its an easy job for him 2 minutes away from where he lives (he literally lives at the other end of the road.
Thanks in advance,
Lee
Thanks in advance,
Lee
