I am thinking about putting a tri-fold door in. I see no one mentions to tie the cavity leafs together. The hole is to be 2400x2100 . Do you have to do this?
The cavity walls will already have ties. Or, do you mean cavity closers at the jambs? The cavity lintel you install will also act as a sort of tie at the top.
