Hi Guys,
I have always received fantastic help here, so I'm asking for another bit of kind advice, please.
I am gradually doing and getting my house done as the years go by. Kids being, work, a business and a part time degree are taking up time, but I try at every chance I get.
Got my roof re-felted, chimney removed but I'm still not 100% happy that there shouldn't be a bit less condensation up there. In periods of extreme cold and humidity the joists are cold and slightly moist to the touch where they nearest the coldest area of the loft (where my roof is raised from the terrace line to allow for the bend in the road). My moisture meter zooms to red on those areas, although nothing is dripping or anything.
Where I need a touch of kind help is just on a couple of areas so that I can kill the issue before next winter.
1. What is the best atmospheric meter to use and is it worth it?
2. Are those covers for inside the loft hatch worth it? I have a well fitted sealed ladder hatch.
3. Does that creature on my photos look like a bad thing?
I can't explain enough how helpful the advice has been to me here, so if you could help please, that would be ace.
Thank you kindly
Niven
Thank you kindly
Niven
