I'm installing a new bathroom suite for a customer but they arranged for the electrician to come in and sort out the electric supply for the shower. However, I am a little concerned as to how safe he has left the wiring for the new shower and, not being an experienced electrician, I would appreciate some advice.
I had already disconnected the original electrical supply for the shower and made it safe and the electrician has connected this supply to the "mains in" terminals on a fused switch outside the bathroom. From this switch a new length of wiring goes through a stud wall to a pull-cord ceiling mounted switch next to the shower. Then there is a final length of wiring from the pull-cord switch for me to connect to the shower when I install it.
However, despite checking that the fused switch outside the bathroom and the pull-cord switch next to the shower are both off, I have tested the wire he has left me (bare-ended I would add) and it is showing as live. How can this be the case if the two switches are both off?
Any clues would be appreciate.
