Bit of help needed.
24 Jul 2022
Hi, my house guttering is next to useless. One of the biggest problems is that the main roof guttering on one side of the house goes to a downpipe that just opens onto the attached garage roof. The water flow just overwhelms the garage gutter. So I have rain water flooding over the garage guttering and getting into the garage. Is there anything like a side venting hopper that I could use which would take the rainwater from the roof downpipe and feed it into the garage guttering which I think I need to change to deep flow. Thanks
Could you use some downspout to divert into the drain? Or at least into the garage downspout? Perhaps a photo may help.
Hi, the problem is that the only drain is at the far end of the garage. So all the rain water from the house roof goes down one drain pipe leading onto the roof of the garage roof. This then means not only has the guttering on the garage to deal with the rainwater from the garage roof, but also the house roof also.
So take the roof downpipe to the drain at the back
