I've started drawing up a replacement garage but I'm not sure what way to go with the DPC/DPM. I'm a structural draughtsman to trade so I don't know much about the wood and bricks side of it!
The garage FFL will be a good bit below the houses DPC (approx 600mm ish), what would you recommend doing with the DPM here? I thought cutting it off at the FFL then a few coats of a paintable DPM might work?
At the boundary end my neighbours garden is quite built up (street is on a hill which also doesn't help), again probably 600mm ish higher than the garage FFL. Is what I've sketched ok for the DPM/DPC at this end?
If the details are ok what would you recommend for protecting the DPM? Would timber stud work (only fixed to the blocks above the DPM and overhanging it freely) be ok? Would it then be worth insulating the stud work and plastering over? Or would it not be worth the hassle as the front and rear of the garage will be ventilated?
Thanks in advance
Thanks in advance
