- Joined
- 21 Jan 2017
- Messages
- 112
- Reaction score
- 2
- Country
Guys having a wet room done, battened walls and aquaboarding etc... wetroom is downstairs other side of the wall is external, plumber used bitumen flash primer (white spirit based) on the walls before applying the battens to ensure that damp doesnt penetrate the batten on the interior. Sadly, after he applied this Bitumen on the internal walls brick work we are now left with very very very bad strong smell of chemical bitumen around my home. I am not happy. I managed to enclose the smell in the wetroom buy putting up a zip dust plastic door and sealing of with tape. Vinegar, baking soda, charcoal, all helped but the smell returns.
Also used some DPM membrane sheet to cover the walls which helped in reducing the smell but once you take these off the smell is horrendous.
The plumber has not come back, it seems that this smell can be enclosed. But my question is what can i enclose it wit, I know eventually i will batten, aqauboard, tank and tile my wet room and seal off to a finish, and eventually that will stop any smell coming out, but that does not sit well with me and id rather work at trying to cut of this bitumen from releasing odours before i continue with the wetroom. I cannot remove it, its really painted well one coat so not thick.
What can i use to paint/brush on top? can i SBR bond primer it ? but thats rubber, will that smell too? or is there any kind of liquid based sealer which can be applied on this product, to seal of the walls and stop this horrible smell.
Please if anyone could help me.
This is what he used and this is my room :
EVERBUILD Bitumen & Flashing Primer 5L
INGREDIENTS : BITUMEN (WHEN IN SOLVENT SOLUTION) 50-70% EINECS: 265-196-4 CAS: 64742-93-4 [Xn] R40; [-] R10 • WHITE SPIRITS, NAPTHA (PETROLEUM) 30-50% CAS: 64742-82-1 [-] R10; [N] R51/53; [Xn] R65; [-] R66; [-] R67
Thanks.
Thanks.
