Bitumen Surface=DPM
15 Mar 2016
Morning all, I have a question similar to some on here but not quite the same...
We have a late 1950s bungalow which we're working on room by room. The lounge had vinyl floor tiles which were removed over a smooth bitumen layer which now remains. I've read a number of conflicting things about this - is it actually the DPM? If so, can we leave it, underlay and carpet over the top?
If not, is it a case of using DPM underlay with wooden flooring over?
I'd appreciate any pointers. Thanks very much in advance.
oddnumber, Hi.
In 99.9% of cases in property of this age the "Mastic Asphalt" top on your floor will indeed be the DPM
Suggest a look on Google, there is a site as I recall called something like the Mastic Asphalt Council [or some such] where there is a load of advice and information from what I believe to be a reliable source.
One area I would attempt to investigate is a De-Bonding layer between the underlay and the Asphalt?
Ken.
Awesome, thanks Ken. I've since spoken to a very helpful and knowledgeable chap at a local flooring company who has suggested screed, DPM, screed, then floorcovering.
All isn't lost! :)
