Hi!
Working on adding a double socket to an existing Ring circuit (32A MCB), I isolated the circuit and every time the MCB was off, the RCD tripped. the thing is that it does not happen immediately but after 5, 10 even 30 minuets. I checked the circuit and the R1+R2 values as well as the insulation test are in the range allowed. when the MCB is on it does not happen. this is not the only ring circuit in this installation. any ideas?
Many thanks, Albert
Many thanks, Albert
