ukdan said:
Cheers Jon, i really appreciate all the work you put in for me. According to the label on the back of my pc, the model is "pc mt6" and the type is "med mt 163". The medion s/n is 11109010050648. I did look at the medion website for updates but the instructions tell me to copy the update into the E folder. Problem being, i got rid of all that when i put the new hard drive in so there is no E drive. I have been told i can upgrade the bios using a boot disk but i don't want to try until i'm sure incase i blow the house up!!!
That's not a problem.
Right, the correct BIOS update for your computer is as follows:
http://www1.medion.de/downloads/download.pl?id=245&type=treiber&filename=biomd5kv11.exe&lang=uk
As regards extracting to E: just ignore that, i have amended their instructions below which should help, the bits i have changed are in italics:
Medion AG
Bios Update
1.1H
Supply date 12.10.2005
Made downloads 172054
Bios Update of the MD 5000 (Rev 1) mainboard
+++Instructions to update your system bios +++
1. Unzip the downloaded file by
double clicking on it, it will then prompt you for a location, just type something like c:\newbios
2. Afterwards restart your PC with the Application-/ Support-CD.
3. At the MS Windows CD-ROM-Bootmenue choose "Boot from CD-ROM".
4. After that select "MS-DOS Prompt" in the Application-/Support-CD Startmenue .
5. Finally execute the md5000.bat file which can now be found at Partition C: into your specified folder.
You do this as follows:
At the command prompt type the following:
c:
You should now see the following:
c:\
Type cd newbios (or whatever you called the folder you extracted to)
You should now see:
C:\newbios
Type dir, then hit return, you should hopefully see the file md5000.bat in the list.
Now type md5000.bat and hit return, this will launch the batch file that will update your BIOS.
6. Now start the update procedure by pressing any key.
7. After the bios update please reboot your system.
Please be aware that you noticed the original bios setting before starting the update, because some values may have changed afterwards.
Important:
For any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.The customer agrees with that fact by executing the update.
The above should carry out the BIOS update, you can confirm this by looking at the screen when it boots following the upgrade.
Good luck!
Hope it works out OK, it stopped raining here so i'm gonna go cut some more timber for my deck
Jon.
