I'm after some advice on laying a black limestone hearth which will be home to a wood burner.
The hearth will be 1.4metres wide beyond the chimney recess and 1metre inside the chimney. The new hearth will sit on top of what's left of the concrete constructional hearth.
Firstly, I doubt I will be able to find the exact size flags I need, so will need them cutting and dressing. Is this something a stone supplier should be able to do? (I'm in West Yorks if anyone can recommend a supplier)
Secondly, I have read elsewhere that I should lay the flags on a fairly soft bet of sand and cement. What mix should I use? A friend suggest 1:4 using river sand? The constructional hearth is not symmetrical - one side of is about 4cm longer than the other. The end result is that the flag will be seated on the wooden floorboards. Is this going to be a problem?
Next, I'm conscious that these flags can be easily stained. Should I seal them before I start any work with them - ie before I even lay them on the base? I've read that Aqua Mix Enrich & Seal is a good solution. I don't want a sheen on the flags, just to protect them and if there's a colour enricher, then great.
Finally, do I grout them with tile grout or traditional cement based?
Many Thanks!
Many Thanks!
