I was laying patio wall foundations the other day when tired and on autopilot I just. Opened the bags and threw them in the mixer.
My problem, I mixed the equivalent of 2 or three 25kg bags of ballast (filled from bulk bag) and 1 of building sand (mistaken for the other ballast bag) mixing at 9:30 in dark I didn’t notice till id added the cement and turned flood lights on.
It’s 3” below ground level, 4” deep with eml reinforcement in and has 6” of normal concrete under it.
Mix was 4:1
It’s basically a four course reclaim wall a bit loosely laid (rustic) with a concrete haunch on the inside to fill with type 1 mot and wacker down for my patio top to go on.
Personal only not a customer job. It’s all really rustic, big joints, not perfectly seyarebdeep jointing looks worn and old. The bit in question is 40cm long and has 1 brick on top as it’s on a terraced bit of the garden . I used extra concrete to save using a lot of bricks. It’s 14” wide.
Do I sds drill it out and try re do or leave it?
Never done this before. At that mix I’m only really worried about frost resilience. It’s rock hard .
Mix was 4:1
