Bleed a Heatslave II (2) 18/25
5 Jan 2018
Hope someone can help, I have a fairly new boiler, only a year old and we've unfortunately run out of oil. It won't fire up after hitting the reset button now that I have some oil, so am assuming it will need bleeding.
I've been going through the instructions, and it seems the bleed valve is behind the right panel of the boiler. Stupid question, how do I get the panel off?! I can get the top and front off fine, but it seems I need to take half the boiler apart just to get to the side panel off to bleed it!? Am I misunderstanding? Is it simpler than I'm making it?
Documentation for the boiler here... https://www.plumbcenter.co.uk/wcsst...i/on/Worcester_Heatslave II _Installation.pdf
Any help will be greatly appreciated!
Dave
Once the front panel
Is off you can see the burner at the bottom right ( the red unit )Remove the 2 screws holding the red cover on. Then on the left you will see a 3 inch long hexagonal bolt with an Allen key in the end. This is the bleed point for the oil
Be careful have some cloth you may spill a lot of oil and don't press reset too many times or you could end up needing a new oil pump.Bob
