Hi guys,
First off, I’m not a plumber, just a simple tenant. There’s a radiator/towel rail that has cleverly been fitted on my bathroom wall where the bleed valve is right up against a side wall and so can’t be reached. The radiator does get warm all over but not as hot as normal radiators so I wondered if it needed bleeding... but the valve can’t be reached.
So 1. Is there any other way it can be bled? And
2. Is that unlikely to solve the problem?
Even if 2 is a yes, could someone please still answer 1, in case I ever did need to bleed it.
Cheers.
Cheers.
