Hi all,
Just fired up the heating after the summer but two of the upstairs radiators were half cold, so I bled the first successfully with loats of air comming out but when I bled the second rad it was sucking in air (checked by using a piece of tissue which was sucked to the hole)
I warmed the system first and I switched off the pump and boiler before bleeding.
The system has had corrosion inhibiter in for many years, the system is about 16 years old and I have been here for 7 years without a problem.
I have tried 3 times to bleed this rad and every time it sucks in, when I then fire up the pump afterwards it is then full of air.. what is happening please?
Regards
mocke
Regards
mocke
