Bleeding a radiator
22 Oct 2005
Cheshire
Hi
I was trying to bleed a radiator but the screw valve thingy (you can see I am not a technician :oops: ) was snapped by the radiator key so now I can't unscrew the valve.
Is this a new radiator job? Or is there a way of replacing that bleed valve? Can relpacement bleed valves be bought at the likes of B&Q?
Any help\advice greatly appreciated.
What type of endcaps are you looking for. Can you supply a pic. I have just taken some rads out and if you send a sae, I will end you one foc. No need to replace the whole rad. ;)
