I am trying to bleed a radiator but the bleeding nut is worn and I cannot get a grip.
I have tried 3 different keys.
Any ideas or cunning tricks I can try?
you could try a decent pair of pliers, or quite a few rads have removable bushes that the bleed nipple screws into. failing all else, a new rad.
Your problem is caused by overtightening the bleed screw.
Try sacrificing one of your bleed keys by squashing it slightly in a vice, just to make the square slightly oblong. Remove all of the paint from the bleed valve area, tap the 'modified' key on and see what happens...worth a try!
John
It sure can't do any harm - likewise heating it up a bit.
The trouble is, brass is very soft so the bleed valve is likely to crumble. I presume you've tried some snipe nosed pliers?
John
John
Hardly! Brass though is inherently a soft, granular metal that doesn't like to be mauled about.
If the nipple isn't held in its own hexagon housing but is blind into the rad, I'm afraid you'll have to replace the rad in the end.
John
