I have always read that you should always bleed radiators with the central heating switched OFF.This was to prevent more air entering the system and causing potential oxidation and corrosion , further problems down the line.
Is this correct?
I'm a bit concerned because the boiler was serviced by a gas engineer,he then turned the central heating on and bled a radiator without switching it off again.
Cheers.
JS
Is this correct?
Cheers.
JS
