Hi, I have recently had some work done on our central heating system and am trying to get rid of the air introduced (which might be the subject of a longer post another time).
When I read on the internet (including this forum's FAQs) about bleeding radiators, they always say wait for the hissing sound to subside and then stop when the water is coming out.
However it doesn't seem to work like that for me, at least not always. Quite often I seem to get a mix of air and water. Also sometimes it seems like I get a flow of water, but if I open up the bleed valve another quarter turn then I get another hissy mix of air and water, then maybe that will subside, but if I open the bleed valve further then I get another hissy mix of air and water....
We have eighteen radiators in the house, of which four are towel radiators, of which two are very nice looking ones but they have the bleed valves on the underside of the top bar, I'm guessing that is a case of aesthetics over function. Those two are the worst for a hissy mix of air and water, but I also sometimes get it from the other radiators.
So I suppose my question is why does this happen and should I just be getting lots of towels and keep on bleeding until I can open the bleed valve fully and I'm satisfied I'm drawing only water out rather than a mix?
Gavin
Gavin
