Bleeding rads!!!
23 Jan 2007
Lincolnshire
Hopefuly someone can help , bleedinbg the rad as there seems to be a bit of air tin the system, bubbling noises! Iv turn heating off first then bled the rads some seem to dribble others spray out at high speed , but does not seem to be any air.
what is causing the high pressure should i bleed until it slows down ?
Any help would be great
No just bleed the air out until the water comes out, its squirting out because your system is under pressure, as it should be.
