Bleeding system (venting spleen after drain)
1 May 2005
Lancashire
Refilled (slowly) after drain down for new rad fit.
Old Gloworm boiler
Gravity hot water (primatic fortic tank) ok
4 out of 6 rads working ok.
2 rads not working on ground floor.
All been bled to death but no joy.
Crackling noise from pump Myson (unit two)
Assuming airlock inpump?
? can I crank the power up to position II to force air out?
Is that little black plastic knob on the casing the bleed valve.
ThanQ
Thanks Kev
but can I crank up the power with the little black rocker switch marked I / II to force air out if its elsewhere in the pipe system?
Primatic- fortic :evil: You have my sympathy- Are the downstair rads on drop pipes from above?...Try shutting all the other rads and turning up the pump.
