Bleeding
22 Oct 2004
Many thx boys, advice stop on! :D But 1 last 1 hopefully. i know i have to bleed from the bottom of the system which happens to be the boiler in the basement (glowworm 40) do i do this via the drain? or is there a bleed screw? :confused:
bleed the rads and the pump hot water cyl if theres a bleed point
should sort you out
if you have a fully pumped system make sure the valve(s) are open (lever on side) :D
