Hi all, looking for some experienced input on a task I am about to under take.
Currently our bedroom has a little alcove off 1 corner making use of space over the stairs as shown in the brilliant sketch below:
We are redoing the whole room, and one of the improvements planned is to build a stud wall & door frame over the front of the alcove as per below:
The opening is not much bigger than the outside of the full height studs when including door+jambs+jack studs+rough opening clearance, but will still require a small amount boarding and plastering.
From an overhead view this is what I have in mind:
Door jamb depth will be 119mm, so stud width+2x12.5mm board+2x2.5 plaster should bring the final wall surface to the same depth as the jambs.
My main question is, with the plaster layer, will a decent blend with the adjoining wall be achievable?
