Can you lay blockwork on top of block and beam floor to create a wall partition, they will not be load bearing just on single storey with flat roof aboce. I want to subdivided the floor area into 3 separate rooms.
Theoretically if the supplier says it's OK, normally you would fit a double beam beneath a wall running parallel to the beams. So it begs the question is the beam and block already installed?
