Just had the following comment from the plan sheet / outcome from my private building inspector.
For an area of approx. 60m2 of new extension, how much more will block and beam cost me compared to the alternative and which is better? I understand B&B is quicker to install than the other but are there any other advantages. Would my architect have proposed B&B due to trees near by?
Please provide manufacturers details to justify the adequacy of the proposed block and beam floor construction. Subject to item 2 above and the ground conditions found on site it may be acceptable to provide a ground bearing floor slab as specified for other areas of the work. Advisory - If underfloor heating is proposed in areas where a ground bearing floor slab is to be provided it may be more effective to install the floor insulation above the concrete slab with a slightly thicker screed.
And separately why does the installation of a GRP roof need to be done by a registered installer (another condition he put). Surely not all roof installations need to be registered?
Thanks.
Thanks.
