currently in the early stages of planning a double storey extension to our home. The current house is facing brick on the bottom (roughly 3m in height) and then rendered above to the roof.
Defo wanting to keep the outside visual the same as currently is, just out of curiosity however, what is likely to be under the render of the current house? Will it be the same facing brick or block?
For the extension I was wondering if, financially, it would be more cost effective to block build the top half of the outer wall for the rendering (price per block against brick - against the area it would cover?).
Thanks in advance.
Thanks in advance.
