Hi guys.
Anyone have any thoughts about the usage of the below blocks for a single story flat roof extension
The celcon solar blocks
https://www.travisperkins.co.uk/H+H-Celcon-Solar-Aerated-Concrete-Block-2-9N-100mm-Pack-100/p/701733
Vs
Celcon Hi strength Block
https://www.travisperkins.co.uk/H+H-Celcon-Hi-7-Aerated-Concrete-Block-7-3N-100mm-Pack-100/p/837344
I personally like the idea of the solar blocks as it’s a better insulator but weaker compressive strength. However builders are spec’ing hi 7 blocks.
Understandably the costing of these blocks is roughly the same.
But, considering the tech sheets say the solar blocks can handle loads of up to 2 stories (my house is 2 stories) it seems overkill for the hi 7s? Maybe it’s one of those let’s over spec just in case. But I know I’ll never get any more than 1 story in this spot.
Although if I’m considering both these blocks, it seems that the standard blocks (https://www.travisperkins.co.uk/H+H-Celcon-Standard-Aerated-Concrete-Block-3-6N-100mm/p/700055)
Have a best of both worlds in Terms of insulation value and strength. And it has an added benefit of being considerably cheaper!
Is there a reason my quotes are specing these blocks that are overkill for a single story? Am I missing a point somewhere? Is it a better be safe than sorry moment?
Vs
