- Joined
- 15 Sep 2024
- Messages
- 3
- Reaction score
- 0
- Country
I have a detached single leaf brick garage which I'm converting into a home office. It dates from the 1930s like the house I think. It has an up and over garage door with a solid oak(?) lintel. There are piers on either side os the opening - the left one in parallel with the front which means there are two courses where the opening is. The opening is off centre, so on the right side the opening is up against the straight wall, there is no corner. The pier there is in line with the wall, so there are two courses for the first 500 mm or so.
The opening itself is 2350 wide and 2240 tall. I'd like to put a 920 wide UPVC door on the left, so about 1400 wide masonry to brick up. The DPC is about 120 above the floor slab, so I was thinking a block on its side (100 plus 20 mortar bed), then a DPC and then tie the new blockwork into the wall with a wall starter.
The concrete base slab is about 150 thick I think - hopefully strong enough to support a one leaf blockwork? Would 3.6N Aerated block work for this? I would render it to match the rest. The weight of an aerated block is 7.5 kg and I think I'll need about 30 of them, so that is 225 kg plus mortar.
Thanks for your advice.
