Hi.
There is a rainwater drain at the front of the house. Recently the heavy downpour resulted in the water rising to a level to nearly flowing into the house.
After the water receded to a level within the drain I cleared all the debris. The (square) aperture is only 125mm and the pipe leading out to the road seems to be about 75mm diameter.
I tried poking through but there is U bend there.
Can anyone advance an idea how I could clear this?. Or would I need to have it jetted?.
Would a plunger, probably work?
Thank you.
Thank you.
