Does this sound like a blocked cold feed ? I've not been able to track the pipework yet to mag test it but.
Potterton 80 downstairs, pump upstairs about the level of bottom of rads, F&E tank in loft.
Boiler started resetting, it was hot , pump was hot but rads were cold and the header tank was full and cold. The pump is spining, and vibrating, but not removed it to check impeller blades
Lots of air in the system, so I try to drain and flush it but removing rad from ground floor. Very little water came out unless I unscrew a bleed tap from a ground floor rad.
During this time the header tank level did not change (ballcock tied up).
I refilled the system via a air vent which is above the pump, and got all the air out the rads. (it took a lot of water)
One switch on the system did run with the CH coming on for 1 min, and then the pump trying to move it around the system. The heat was very slow to move around the system. Sometimes when the pump was off you could hear water flowing back into the boiler.
This worked for about a day before the boiler started resetting itself again.
Does this sound like a blocked feed pipe ?
Its a Grundfos pump, if the feed is blocked does that mean that there would be insufficient head in the system for the good pumping ?
