Blocked downpipe
17 Aug 2006
Buckinghamshire
Dear All. Please Help !
My house built in 1967 has blocked downpipes (imperial gauge) which run into concrete collars. I think the blockage is simply leaves etc but I can't clear it ! I have tried pouring drain unblocking liquids down to no avail.
Does anybody know a cunning plan to shift this blockage without having to break the concrete collar ?
If not, any good ideas how I can break the collar ?
Thanks in anticipation,
Linny.
Linny.
pressure washer
if that fails then try
images
Can't you locate the manhole (aka inspection hole) and rod back from there?
Failing that, you could drill a hole in the side of the downpipe and rod down from there.
try pulling the swan neck off @ the top and lifting the pipe bodily out of the collar @ grnd. level....I`m assuming the clips won`t unscrew :cry:
