This is going to be difficult to explain I think, but I'll have a go.
There are four of us in a little block of houses (two flats at the top and two flats at the bottom) and we share the same drain. The kitchen and bathroom waste from two houses(ground and first floor right - that's me) go into one pipe and into the soil stack and the toilets from the two houses go into one drainpipe and into the same soil stack. A little bit further along the pipe, the other two houses have the same setup and into the same drain as us (I hope this makes sense).
We've had mega problems recently with the drains constantly blocking. We've had the drainer from the Council out three times since the end of November to unblock it and then today, we had to have a private company out again to unblock it.
I had a surveyor under the floor recently and he said that the foundations were flooded with really rank water and it was soaking through the foundation from the main drain which is buried in my neighbour's path.
That was when we first got the Council drainer to come out - the surveyor reckoned the drain was cracked or broken. The drainer said that the pipe wasn't broken (using his x-ray vision) and that it was blocked and that was why the water was seeping through the path and under the houses. He proceeded to unblock it.
Exactly a week later, we had him out again cos the drains were all choked up again.
And I guess I'd better explain how I know.........when I run the taps in the bathroom and turn them off, I can hear the water gurgling in the shower waste - it doesn't come up the shower fortunately because the plumber couldn't be bothered digging a deep enough trench to sink the new waste for our shower and bathroom sink, so it sits right at the top of the soil stack and is only under half an inch of earth - shoddy by him, but handy for us because we don't get the water coming up it when the drain blocks.
Anyway, back to the second visit by the drainer. This time, he brought a plumber with him. The plumber proceeded to tell me that when the roofers were re-roofing the houses (almost two years ago and this would kind of tie in with the time line), they cut off the tops of all the downpipes and replaced them with plastic . While they were doing this, they dropped bits of the cut off pipes down the drains and blocked them. The plumber says they had to unblock all the drains.
By my reckoning, it's possible that they've not got out all the broken bits and this might be causing the drain to block all the time.
Does this sound like a possibility?
The latest event was Christmas Eve when the neighbour next door to me came running through to tell me that all the waste water was coming up her bath. The Drain Doctor that came out today said that it was the pipe that came from her and her upstairs neighbours kitchen/bathroom waste that was blocked. He used this spiraly thing to clear it and there was no gunge on it or anything that could be causing a blockage.
So that brings me back to perhaps there's broken bits of pipe down there?
I honestly can't understand how a four inch vertical pipe can completely block when it's only the contents of the kitchen/bathroom sinks thats going down it.
I ask so that I'm fore-armed for falling out with the Council when they re-open after the holidays.
At the moment, the Council are footing the bill for clearing the drains, but they won't do that forever and I'm sure I'm not paying out £200 a time to get them cleared.
I hope that all makes sense and any advice would be most appreciated.
Thanks,
Alison
Thanks,
Alison
