Woke up this morning to the lovely sight of water creeping up our toilet bowl and overflowing outside where the sink runs into the drains. I lifted the manhole and the inspection chamber was filled with water, the next chamber along was flowing freely. I called Thames Water and they promised to send someone out within 8 hours. Mentioned it to my sister who revealed that the brother in law builds drains as part of his job and has a set of rods. He managed to unblock everything but said there were a couple of issues that caused the problem and will do again:
1. Where the pipe from the first inspection chamber joins the second it narrows from 4" to 2". It serves two houses so is too small. What if anything can be done about this?
2. All the properties gutters empty into this drain as well so it carries a lot of water, apparently this isn't right either?
