Just took me over 4 hours to refill central heating system. I am thinking that filling cock on the boiler side of filling loop is only allowing restricted flow. Reason for thinking this is that flow to filling cock seems to be fine, as judged by disconnecting fill loop with mains cock open, and that after pressurising system the opening of the filling cock (with fill loop disconnected) does not result in flood of escaping water, only a few drips. The latter would seem a pretty good indication that the fill cock is blocked. The filling cock in this system is the one that screws into the main heating cock.
What do you guys think? Any other test I could do?
In case you are wondering, drained system to unblock the pipe to the expansion tank. The pipe was full of crud, fortunately I had a wooden kebab stick to hand. I think the crud was deposited before the system had been flushed and a magnaclean filter installed. Domestic hot water heat exchanger is as clean as whistle. No other niggles apart from a rattle, presumably the diverter value. Not bad for this boiler since is now 14 years old.
