I have a leaking 3 way valve on my vented cylinder CH system, so I decided to drain the system, flush it out and replace the valve. However, the water level in the header tank in the loft didn't go down when I was draining the radiators.
I emptied the tank manually and disconnected the outlet pipe, pressurised the pipe with air to see if there was a blockage that could be moved, but the pipe pressurised. There is a U bend at the bottom of the pipe where it enters the CH system in the airing cupboard, I thought it may be blocked there, so I cut the pipe about 6 inches above the bend and put a wire down there to see if it was blocked. I also removed the pump to have a go from that direction. There was sludge in the pipe, but I think the wire is now hitting the T section where the feed pipe joins the main CH pipe.
I have tried pressurising the pipe with air to see if air comes out of the open pipe near the pump, but it pressurises. It doesn't look like there is a one way valve in the T section of the feed pipe, so I can't work out why it is still pressurising. Am I going to have to cut out that section of pipework and replace it? Please can anyone help. The system is 20 years old. Thanks
