Please help.
I have a blocked hot water supply pipe to the bath. It all started when running a bath, the hot water was reduced to a trickle from the hot tap. (Cold tap for bath and Hot /Cold on sink is running perfectly)
We have had a homeserve engineer out who has removed the hot tap body and turned the water on but no water is coming out of the pipe\tap.
He has found some small pieces of copper tank (outer) insulation foam in the tap when the body was removed. (Looks like when the tank was fitted the pieces of foam cut away to fit the immersion has dropped into the tank and have consequently been sucked into the hot water pipe)
Is there any way of flushing the pipe out without removing the pipe work?
Any advice would be appreciated.
