I hope somebody will be able to help, the central heating at my grandmothers house has just stopped working, typical that it happens when its so cold! I believe it i an open vented system with a back boiler.
From reading a few threads my guess is that the feed pipe is blocked (or possibly frozen given that the fault coincided with the cold weather??)
as when I tried to bleed the radiators there was very little pressure in the system. I also have removed the pump bleed screw and no air or water came out. The pump appears to be running too, this gets hot but the pipes either side do not. I have also tried switching the 3 way valve to manual open but this had no effect. Of course I could be totally wrong as I'm a complete novice when it comes to central heating so any advice would be gratefully recieved!
THanks,
Dan
[/code]
THanks,
Dan
[/code]
