I'm looking for some advice please if possible. My central heating pipes are blocked with sludge and my usual plumber says that I need to get the whole system re-piped.
I have 10 radiators running off a one pipe system and the pipes are all 15mm. I've had the baxi engineer come out and look at the combi boiler and he said the pipes are blocked with sludge which is why the heating isn't working. He recommended a chemical flush (and said that people would try and sell me a power flush but they are more expensive and not necessary.) He said the return flow isn't getting hot so must be really blocked.
When I spoke to my usual plumber he said that all the pipes needed changing to 22mm pipes and made into a 2 pipe system and that either a chemical or a power flush was unlikely to shift the blockage. I don't really have a clue about any of this and just have to go on what is recommended so I was wondering what other people think?
Is it worth me trying a chemical flush or a power flush? I know it'd probably be best practice to get the pipes all changed but I really can't afford it! What I don't understand is that the central heating has been working (it doesn't ever get that hot) since the boiler was installed in 2014, so if I get it flushed then surely it will go back to work in the same way?
Hope someone has some good advice - it's getting colder! Thank you.
Charlotte
Charlotte
