We recently had an extension build, which meant the window to our understairs cupboard was blocked up. I want to sort the space out so we can use it as a coat cupboard. There is the exposed block work, from blocking up the window and some other exposed brickwork where the plaster fell off. The rest is plastered and painted - 1940's looking plaster (with horsehair in it ?) and some shiny paint. The block work is about 30sq cm and the brickwork an irregular 20 cm by 30 cm.
I'd like to cover these two spaces to minimise the dust. What are my best options?
I've got a tub of ready mixed plaster and a tub of mortar which I can mix up. Am I in the right zone? I'd really prefer not to get into plasterboard.
Any advice, gratefully received.
