Blocking existing kitchen door to garden with worktop. Permissions required?
10 Jun 2023
The Victorian semi we are buying has extremely limited worktop space (just either side of the sink). Given the layout of the room the only way we can gain more space is by carrying the worktop to the left, which will cover the back door. We'd put some additional base and wall cabinets there too. We don't want to brick up the doorway, it would still look like the lovely wide period door that it is from the outside, but we'd put some sort of panelling on the inside (carefully thought out re damp/airflow etc) and add the cabinets/worktop in front of this. We don't want to brick it up and lose the door permanently for a number of reasons.
What sort of permissions, if any, would we need for this given it is not permanently blocked? There are French doors still providing access to the garden from the kitchen giving the requisite two points of egress.
I don’t see an issue?
My brother had a Victorian terrace with a rear kitchen door, but also a door to the side passage.
The kitchen had been a series of small sculleries etc. They covered the side door with the washing machine.
I would image that so long as you can’t be trapped in a doorless area of the kitchen by a chip pan fire you’d be ok?
My 50’s house had a kitchen back door which now leads to a utility room and then to a back door.
That (presumably ) passed planning several years ago.
