OK, I accept that this is probably the dumbest question ever , but....
I'm blocking off an internal door, within a block wall. There are a couple of pipes mounted on the wall about an inch from the door. I've removed the architrave carefully, but do I need to remove the door frame or not before adding noggins?
Thats likely to be a lot more destructive, and possibly affect the pipes, or the plaster under them....
Would an alternative be to build a stud partition and fit to the doorframe rather than the wall, and fix the plasterboard to that?
Hope you can help - the missus sprung this one on me this morning...
