blocking old drain in solid floor
23 Oct 2012
London
Any suggestions as to the best way to block/cap an old drain where a toilet has been removed?
It's in a ground floor bungalow where the room is no longer a bathroom. Floor has 4 inch hole leading to manhole outside via usual 4 inch pipe. Nothing else uses the pipe so my thoughts are to block it up with concrete or something equally permanent, then lay the floor on top.
Should I worry about damp coming up though the floor???
Should this be in the plumbing section???
thanks everyone....
