Hi all ,
I hope you can help with the following questions I have .
I need a wall hung gas fire removing and the supply capping off(below floorboards level).
I will get a professional to do this , but I wish to do the following myself if possible to save money
The house is a 190 30's ish semi, normal construction the chimney has a cowl on but is not capped off.
My questions are;
Do i need to fit a ventilation grill in the chimney breast ?, we are hoping to take it back to bare bricks and partially replace the bricks where the fire flue entered the chimney breast with matching bricks.
should the chimney be capped off and if so does this remove the need for ventilating the chimney ?
many thanks in advance for any advice given
Glenn
My questions are;
Glenn
