Hi all
Our house was built in the late eighties of what I would term 'standard' construction. By that I mean twin walls and cavity - if that's the right expression! There were/are two air bricks, one in the lounge and one at the top of the stairs. I was under the impression that the one in the lounge was there due to having a back boiler in the room and when this boiler was removed I blocked up the air brick (using temporary methods) to keep the room warmer. First question is; is this ok? Second question is; would there be any problem blocking uo the one on the top of the stairs as there is an awful draft coming down the stairs which are in the dining room?
I should probably add that we don't have a hall as such. The door from the lounge (where the back boiler used to be) leads into the dining room. The new boiler is now located in the loft with plenty of ventilation.
In short I guess I'm asking whether you believe these air bricks were put in to give ventilation for the old boiler, or for some other reason? If the latter, am I going to regret blocking up the one in the lounge.
None of this was a problem when I was younger and didn't feel drafts!!!!
Many thanks for your time.
Nick
Nick
