Hi all I brought a 1930s house and the chimney opening had been blocked up I drilled some holes in and fitted an air brick a few years ago the house has a tiny cavity but no insulation with how the bricks are built you can’t fit any in
Fast forward a few years and the chimney stack is in a poor state and has recently been taken down to inside the roof itself
Can I block the vents off in the house now mainly in the second bedroom when it has a big opening
The top will be capped off when work is completed
